M-Tech Suspension
clint
Hey Bros,Need your help.1) I am currently on M-Tech Suspension and 18" Wheels. As it is now, the car is damn bouncy. How do i now if my absorber is still working ?2) I have never full load the car as in 1 driver, 4 passengers and boot load of luggages. Anyone with E46 M-Tech and 18" Wheels tried full load driving outstation ?Thanks.Best regards,Clint
I did before but the bouncy feeling is very relative. Did it feel bouncy after you change to 18" or did the feeling came after a while? Well, my rear absorber was totally konked but I didnt knew about it until I upgraded my suspension and the mech showed my rear absorber to me.
The best is let your mech check. Cant really diagnose here by just feeling the "bounciness"...
M-Tech Suspension and 18" were standard on my E46. It was bouncy since the day i got it so i am not sure if its suppose to be like that. I wonder if there is a machine to test suspension.
AFAIK, Puspakom has.....they have this machine which bounces your car....
clint;253921 said:
Hey Bros,
Need your help.
Thanks.
Best regards,
Clint
hello bro...this is wat i can tell from my least experience...
1. simple check as wat i learn from d oldtimer : try to press each corner of ur car. once u pressed it, the car shud bounce once only ( not keep on bouncing!! if it does, then ur car is only sit on the spring, not spring n abs )
2. i have try it b4 when i first installed my car wit 18"...me n my wife+son in front and 2 plus size passenger behind n half loaded trunk. ride is smooth but still experince lil bit bounce when it comes 2 bumpy road!!
my car is also equip wit the m-tech suspension. hope dis will help...cheers!!
