herbert;653767 said:rg470,
You ordered H & R or Eibach ARB? Look forward to your feedback after installation.
Cheers
skarl;653780 said:Installed mine with "UltraRacings" few weeks back and can say its totally different experience in handling, now can 'kona baring' with only 1 finger, I reckon H&R or Eibach should yield better result
rg470;653902 said:Hi Herbert,
I've ordered H&R, was told by the Auto Future's boss that the Eibach ARB's bushings generate noice after sometime and require constant lubrications. I got to know that you're on Eibach from another thread, how was it so far? Will definately feedback to this thread after my installation
herbert;653908 said:I actually wanted H&R ARB but unfortunately H & R is not available for e39 (only for e39 M5). I don't think Eibach bushings need constant lubing as I have installed it since Nov 2010 and no noise/problem sofar. What are the diameters of your H & R ARB?
rg470;653914 said:I see, good for you. According to H&R, its 27mm at the front & 21mm at the back.
herbert;653929 said:Wow!! 21 mm for rear (Eibach 18 mm) and believe me, you will experience lots and lots of fun and with full confidence taking sharp hard corners. However when road is wet/slippery, just take it easy.
rg470;653758 said:Just ordered mine through Auto Future Design, will update the experience in this thread after installation. I've also bought Eibach pro-kit so will install both at the same time, should have significant difference.
lwloh;653995 said:Mind my lack of knowledge herbert, but why do we need to take it easy when it's wet ? isn't it the better handling as well?
Galaxy7;653972 said:mind to share how much the H&R arb?
