JL Audio Clean Sweep
nicholaslkh
Selling this processor away as I have upgraded. This is a device for those who are looking forward to upgrade their factory integrated sound system (without much hassle). There are lots of reviews for this product. Age of item around 1 year plus.Selling it at RM850 (Preferably COD in KL). However courier can can be arranged. Pictures can be provided via email.For fast deal, please call 019-6023398. Thanks.A brief description about the product:1) About the size of a paperback book, CleanSweep® accepts virtually any analog audio signal, from low-voltage line-level to high-power, amplified speaker-level, via its four differential-balanced inputs. With totally automatic level compensation, CleanSweep® then converts the two or four connected analog signals to digital audio with 24 bit effective resolution. 2) CleanSweep® applies the power of its state-of-the-art, 32-bit SHARC® DSP processor to automatically equalize each of the four channels with 30 bands of equalization (that’s 120 bands total), effectively correcting the response of almost any factory-equalized, full-range signal. These digital-domain corrections will range from subtle to dramatic, depending on the degree of equalization engineered into the factory audio system. To accomplish this complex feat, you simply load the supplied CleanSweep® calibration CD into the factory-installed CD player, set its volume control between 1/2 and 3/4 volume, play the designated calibration track and then press the “Calibrate” button on the top of the CleanSweep® processor. Approximately 20 seconds later, the CleanSweep® is finished analyzing and equalizing the factory-installed source’s response and stores the corrections in non-volatile flash memory. 3) CleanSweep® then converts the digitally corrected signals back to analog audio and sends them out to your aftermarket amplifiers through two pairs of low-distortion, 8 volt (RMS) line-level outputs.4) CleanSweep® includes an intuitive rotary user interface (a knob with stops at both ends) to control the master system volume at the outputs of the processor unit for both the OEM (factory) and auxiliary sources. The master volume eliminates the effects of any equalization that is dependent on the OEM volume control position and allows a high signal-to-noise ratio to be maintained in the system. When pressed, the master volume knob also selects between the OEM and Auxiliary source. A dash-mountable status LED changes color to indicate OEM or AUX input modes. These small controls can be easily mounted within reach of the driver. 5) CleanSweep® can be deployed in signal-sensing mode, powering up and providing a 12-volt turn-on signal for aftermarket equipment whenever signal is detected. It can also be activated by a conventional 12-volt trigger, if the OEM system provides one.
does this allow me to output from OE headunit to a new amp (subsequently to my sub & components)?
this is for a e60 actually.
tq, pls pm me.
