Hi all, This month I have spent quite a bit on my car i.e wheel bearing change n donuts. I am planning to do the following flushing hence much obliged if any could advise how much lube are needed and the lube specs. Can I use Petronas lube and please advise on the specs of the lube should my preference lube is not feasible:- 1. Brake fluid 2. ATF3. Axle Oil - Never change before. Usually on the above flush, what would be the interval change for a full flush? I have done the ATF flush, would need to check when was the last change done.
