nizama Club Guest Joined Jul 31, 2007 Messages 3 Points 0 Nov 30, 2009 #1 My e36 has a scary low pitch howling noise after releasing the accelerator at 60-80kmh. At higher speed the noise do come but always after releasing the accelerator pedal and less prominent. Do appreciate any comments from Sifus around.
ICEMAN 68 Founding Member Joined Dec 4, 2004 Messages 8,055 Points 0 Nov 30, 2009 #2 could be coming from your wheel bearings ..... or at worse the long shaft coupling ....
megatniza Club Guest Joined Apr 25, 2005 Messages 1,681 Points 0 Dec 1, 2009 #3 yes , had the same problem - luckily it was the rear bearing . a pair of rear bearing should set you back around rm250 .
