How to fix it?
anakin
Official Member
Common on E34?Broken clips, that all...but anyone know how to fix it? Tried to use double sided tape, no success...is the pillar available at chopshop? Try BA, they dun sell the clips...:(:(
The broken clips..
try to use Gum Gajah (this is how i call). the one in a liquid form like water.
have used tht for my wira for the same problem. it works.
just my 2cents. good luck
double side tape will come when in the sunlight.
Try using the black sticky spoonge glue that they use for aircon.
Rubber glue to be used if you are not planning to remove the panel again.
Black silicon (those used to install windshield) works well too and is removable.
