HiI have problem with the wiring for trans module to main power relay. I'm using old wiring from my GM gearbox but it had some issue with "trans program" message and my gear stuck at 2nd gear. I suppose this because using different wiring instead of original wire. This problem happen because my new gearbox wiring is being cut off so don't know the right configuration for it.Here i attach some of the picture that might help you guys. Actually i don't know what my gearbox. Either GM or ZF but i know it 5 speed.My Trans ModuleTo Main Power ConnectorWiring to transmission ModuleThis cut off wiring to main powerSo anyone who could help me identify the correct configuration and solve my problem are welcome..thanks.
