help needed
cas
Help !!!! yesterday i tried the OBC diag, after that when i try to start my car all the light is dimm, even the room light is so dimm, then when i try start it try start once with low kick then no kick at all, i tried to jump start and it succesfully start so i let it run for 30 minutes, then after 30 minutes i turn off the engine and try to start again it has no kick and all the light is dimm as well, i took out the battery, its a hydrometer battery i see the light indicating is green, which means the battery stated in good condition, please advise !!!! is it battery prob alternator or ingintion chip, if the battery indicate in green colour then when plug in without start when opening the door why all the light so dimmpls advise sifus
Don't trust the hydrometer green indicator, the last time my car using those kinda battery also shows green indicator but still the battery is weak. How long have u been using those batteries? If more than 1-1/2yr just go and change it.
ok but how do i test the alternator ?
btw what is the recomended batt for e36 ?
and does it will effect any of the electronic parts as when trying to start all the lights indication on an off many time
If your alternator is not working, the telltale light on your dashboard with the battery sign will light up even after you have changed to a new battery when the engine is on. Recommended battery geee check your owners manual, sorry i can't remember DIN ?? for E36 cause me now driving E30 hihihihi. Naahh i dont think it will damage any electronic parts, its just low voltage supply. What car is urs?E36 318i?325i?328i?
your wire terminal clips at battery loose issit.....??? or your alternator grounding loose issit??? or...you battery flat liao.
the best diagnostic on battery power is like this...
Left hand pointers finger grounding( - )
Right hand pointer finger ( + )
grop a 12v bulbs in your mouth...do not swallow it.
wet both fingers and touch the terminals.....and mouth.
If you felt electrocuted and bright lights coming from ur mouth.....wala!!!! Good Power!!!
Go to any mechanics to check your car..please.
cheers.
cheers.
urrrm pull wat to switch it on aaah? :D
no switch needed... if you cant stand the shock..then taped a 10A fuse on your right pinters(+).
Back to topics...
Seriously..please send to your mechanic.:cool:
got it fixed changed my battery
thanks for bro lionel he gave me some good tips when i called him regarding this
eh.. bro zoggee... he say our tip no good woh.... how like that.. hehehehehe :D
