pujiesss;203271 said:My gear knob stopper got stuck yesterday, I can change from (D) to (R) without pushing the stopper.. help! ..
pujiesss;203287 said:thanx sesat88..
good2... em, if want to upgrade to e46 knob, how much da cost? including gear lvl shaft and installation.. how much how much?
pujiesss;203349 said:thnx a lot buddy sanjay nv.. much appreciated. well, its da 1st prob by da way. just got 'my love' last week.. hehe~ can anyone recommend me a gud mechanic? im in ampang.. i really dunno much about car (learning ) n need a gud mechanic dat dun tekan2 to refer to. anyone?
jarance;203369 said:No lah... the e36 have a sponge thing that push the lever out and prevent you from shifting to D to R mode.
To repair, just removed the handle with a torx key. cut a small piece of sponge about 20mm X 10mm X 10mm. Trim the sponge if necessary to fix between the handle lever.
I have used sound proofing sponge (air con) and it works well for me.
pujiesss;203481 said:thnx a lot jarance and genius328i... much appreciated.
so its not allenkey rite? i tried 4 n 5, its just not fit. its a torx key izzit jarance? so need to find BM mechanic.. any idea where to go in ampang?
sesat88;203416 said:hmmmm... now that i haven't tried before. Thank for the advice!
jarance;203491 said:Only if you feel that the lever at the shift handle feel like there is no spring effect.
If feel that the lever have a strong springy effect, then it most likely the plastic lever inside that is dislocated.
yeah, another thing is that I remember that the rubber spring cost about RM10 when I change it at the workshop. DIY.. 20 cents.
sesat88;203517 said:hahaa.. i never feel before got sprint effect on knob, coz it has been stuck every since i got it! .
jarance;203522 said:that is what we call the new version of steptronic..
you step on the acceleator and shift the gear by a cronic
