Ghost In The Machine
JDY;192724 said:
There are two screws near the afm ... my mechanic showd me how to do it..just make sure one end of each metal part of teh screw driver touches both screws..the ignition must be on..n it will start
hey that's how i start my landy... hahahaha.....
careful dude....BMW....ecu can ka-boom :eek: . my 2 sens.. better go get that electronic iggy changed!!!!
yoke;192398 said:
Shiva, thks for the info. If I'm not mistaken I've change the starter, will have to check with my mechanic though.
What I do know, I've change, the connection on the igniton key (cost me RM2++), change something at the auto gear lever (dont remember what its call) but it's quite filmsy like plastic circuitery. Accoding to my mech, the starter has no problem, as when the thing happen, there are no current going to the starter. He's quite puzzle with the thing also. Have already inform him on the possiblility of some switch on the gearbox (cant really remmember this as someone mention it to me on passing).
At wits end already. Somemore sold my car already, I can choose to just let it go, but I choose not to gave the new owner a bad experience of owning a UDM. Most of the wear and tear (bar the gearbox and engine) has been done. So this one problem is really a pain in the ass.
The thing is, when it happen, you just relax or go have a smoke for around 20-30 minutes and then when you try to start again walla as if no problem it ignited and the problem will be gone for 2-3 month (depends sometime longer). I suspect it happen when the car is really hot (or moving for quite sometime) then when try to start it would come to that problem.
But WHAT CAUSE THE PROBLEM???????
hmmm.... did anyone check the S-E-W(manual) mode switch? :eek:
JDY;192725 said:
Sadly he wasnt able to figure it out...that was for a different problem ..hahah..hw's the e46?
Well, for one, it doesn't die off at traffic lights.. hehehe.. j/k..
Let's TT under that tree one of these days.. Chill..
Try another mech la.. I'm sure someone would figure it out..
Hmm, care to explain, where is this switch located?? Not sure
