Gear Box Oil E46
KelvinTeoh
Banned
I just change my gear box oil(Esso Fully Sythetic)at 88K Km,Is amazing,The Torque for the car increase 20%.the max to fill uf the gear oil is 6 Litre,By the time i change the gear onlyleft 5 Litre,it dry uf itself after sometime.Try it out!
what's the recommended mileage to change the transmission oil?
what brand & specs transmission oil do you guys recommend?
pls advise.
thanks alot.
pls advise.
thanks alot.
use only Esso LT 71141, change it every 30-40,000KM
Try it out!
how do u measure the 20% bro ???? curious to know.
Shell has a gear box flush (white bottle, 4 litres packing) which I saw being sold at one of their petrol stations. Since I was thinking to changing my ATF, I would appreciate any comments/advice if I should use this gear box flush before topping up with Esso LT 71141?
The instructions at the back of the bottle said that one has to replace the ATF with this flush. Keep the engine idle for 20 - 30 minutes running through all gears. Remove the flush completely and replace with fresh ATF.
:listen::106:hello. I recently flush my gear oil at a mechanic in Kelang gate. They use brand Vaico, and the recommended mileage is about 80 - 100 k km per flush. It was made in germany and that mechanic is specialised in bmw dan mercedes
i supposed the increase in response or power or whatever is rather subjective...
thanks for sharing, KT.
will definitely change mine once i collect my car coz i plan to service my car as well. and pray hard everythign goes well.
Since my gearbos is from ZF, so I when I first change my ATF, I use ZF oil... So far so good. And the price is quite ok... 1liter = RM63
i bought my car 1 month n i saw some oil leeking.yesterday i went to my sifu n this wat he change sump gasket 65
pulley oil seal 70
oil filter housing gasket 10
oil filter housing seal ring 20
auto trans filter L77114 (8liter) 400
auto gasket 135
auto filter 75
auto cooler hose bracket 24
oil sump 100
labour 140
total 1039.00
pls give comen about my sifu price
