Gear Box Oil E46
KelvinTeoh
Banned
I just change my gear box oil(Esso Fully Sythetic)at 88K Km,Is amazing,The Torque for the car increase 20%.the max to fill uf the gear oil is 6 Litre,By the time i change the gear onlyleft 5 Litre,it dry uf itself after sometime.Try it out!
wan syahmi;369930 said:
change atf oil every 15k to 20km...
That is a very bad advise bro ... wasting money and throwing out gearbox oil which is still good for at least another 20k. the norm is to change every 50k and you're good to go. For me personally tho i change every 30-40k if budget permits that is ...
i change the ATF every 40,000KM, if you drain the ATF at 30,000, u can see that the ATF is still gold in colour (still clean)
A lot depends on your style of driving but 40k sounds about right tho .... but changing at 15-20k is a total waste of money.
And change the filter too, additional around RM60 the last time I did it
Bro zeedo, you did it at AB Kuantan or other BMW mechanics in kuantan? I'm looking for alternative BMW specialist workshops to go to for my future servicing/repairs. Any contacts to share bro? Thanks.
change the atf oil just rm500 only include filter, i do at panjang ulu klang. i can feel the different after every change.
Just rm500??? what brand of ATF do you use and how many litres do your gearbox take??? please enlighten us :rolleyes:
6 litre... include filter. origional from segambut, or from esso packaging...ori 100% brake pad front just rm290 there
KelvinTeoh;370511 said:
esso syntetic ATF per Litre RM68.00
E46 using 6 Litre.
Depends actually some 6L some 10L .... just browse thru the maintenance thread
I'll be changing my ATF oil for my 325i E46 03 model together with regular service..
mileage at 50k now
will give FR on the "after" effects
