hi there,i just had my e34 (525i - 24V) service 2 months back. Just clocked around 3000km (normal town used) and the engine oil seems reduce around 2 litre or more as my engine oil sensor triggerring when turn off my car (new enginer oil sensor). I checked that no white smoke seems coming from exhaust nor leakage as change the oil sump gasket last year. Any other reason why the engine reduce so fast? If the engine really need to be overhaul, what is the best option:a. change to newer half cut engine?b. overhaul by changing piston ring, valve etc?how much will it cost for both option a and b (if anyone having any idea)?Kind advice is very much appreciated.Thank you,TC
