Engine Overhaul
Teralius
Hi guys, My engine oil keeps dropping even though i changed it to thicker oils. My workshop tried using the oil system treatment but it only works for awhile. Are there any other ways to fix it besides overhauling the engine? =(
bro is it dropping without any leaking?i to is facing engine oil level drop..need to top up freq. using 5w40. i couldn't see any visible leaking. friends told me that the there might be a gap at the piston causing the oil to burn..
my e46 318i 2.0 needs to be do the top overhaul
this is due to the overheating engine and water go in the engine (as what mech told)
very bad n very sad
did changed the radiator fan but ok for a while only
need experts advice here.
how much does this cost?
very bad n very sad
Thats what we call blown head gasket bro. If its true then dont wait go get it done quickly otherwise you might need a new engine soon
very bad n very sad
bro.. i think you might go to here..
http://www.bmwclubmalaysia.com/forums/showthread.php?13918-E46-Part-and-Service-Cost-II/page47
every cost you can compare and do reference can save your pocket..
rg470;645187 said:
Did my major repairs at M Speed recently
Engine top overhaul RM3500
Rowe 5w30 engine oil and filter RM270
Time sensor RM280
Engine oil cooler RM580
Gear oil cooler RM580
Bosch Ignition coil 4pc RM600
Fuel pump RM520
Boge absorbers 4pc RM1700
Front head lamp cover 2pc RM440
Original front chrome grille 2pc RM400
Total RM8740
MPS Auto Sunway
Michelin Pilot Sport 3 205/55 ZR16 4pc RM1916
Alignment, wheel balancing and camber RM 125
Total RM2057
Bavarian Auto
Rear trunk brake light housing(rear fog light) 2pc RM350
DIY installation FOC
Grand total RM11,147:13::banghead::43:
credit to rg470
Hi pdot. As Azmi318 has quoted my post at the service cost thread, I would also like to point out a few points in case you are not clear.
Engine overheating can cause "water consumption" as the oil cooler is broken and cause coolant to sip into engine, do check your entire cooling system e.g. radiator, fan, belts, water pump, expansion tank, hoses etc as its quite a common problem with the E46. You might end up spending more than me as I have a different problem, more towards the thread starter's experience (very high engine oil consumption, emitting white smoke). Do get it check asap as you might further damage the engine if left unfixed.
