Van1ty
- Dec 13, 2007
- 334
Engine break-in is recomended by the factory and is followed by most members on this board. The consensus is that proper break in will increase engine life and avoid oil burn. Warming up the car properly also adds to the longevity of the engine. The guy at the dealer will tell you to use their break-in procedure. I used the Procedure recomended by the guys at the performance center and my car never burns a drop of oil. I redline her everytime the road is clear.Clutch,brakes and tyres break in at about 500km. One can also use the ZEKHAUSEN METHOD TO BED-IN THE BRAKES .ALWAYS FOLLOW WARM-UP PROCEDUREENGINE BREAK-IN:1. Dont stay at a certain speed or gear for too long, always vary. Dont excede 170kmph and no full throttle. If you have SMG dont use S5-S62. For the first 900km dont shift above 4300-4500rpm3. After 900km you can shift at a max of 5500rpm. If you go over it is not the end of the world, IMO it helps.4. At around 1300km take a nice road trip about 300km. Remember to vary speed and gear. After the road trip the engine should feel loose and very responsive.5. Make an apointment at the dealer and tell them not to over fill your oil. Wait an hour or so. Make sure the oil is between the two notches on the dipstick and off you go. 6. Dont "abuse her" too much till after 8000km. 7. At 16000km the engine will have full power...But thats most engines.- KILO15 @ M3Forum.net
