Hi,The headlights on my car has started to fade due to it being plastic and our unforgiving weather.Anyone have a nice pair for sale or alternatively anyone know how much would a new pair cost (OEM and original) and from where?Thanks in advance.
Astronyu;649457 said:Sorry to sound noob here but I saw people also sand blasted their headlight, can this also be consider an option? Maybe bro KC can shed some light
aoch88;649578 said:another method is change to lci headlights. Lol
bmw7833;649651 said:Hakim Radzuan and initialM are selling their pre LCI headlight. If u want to save some bucks from buying new, then u may contact them.
aoch88;650869 said:Actually there's a difference between Xenon and Bi-Xenon:
1. Xenon and Bi-Xenon headlights are identical in terms of the bulbs that are used.
2. Xenon headlights use four bulbs, while Bi-Xenon headlights only use two.
3. Xenon headlights switch between two sets of bulbs for high and low beams, while Bi-Xenon uses a mechanical system to set the beam of light.
4. Bi-Xenon headlights are less likely to fail compared to Xenon headlights.
5. Bi-Xenon headlights can be cheaper than Xenon headlights.
6. Bi-Xenon headlights can suffer from mechanical failure, to which Xenon headlights are immune.
cafee;650724 said:Hi guys, more questions
Have found a few sellers - Is there a difference between Pre-LCI Xenon and Pre-LCI non-Xenon ?
Mine has Xenon, will a non-Xenon fit as well , assuming they can move the ballast and bulb over?
Has Anyone tried or knows? Thanks in advance
