E46 replace Flywheel Oilseal
OldmanBM
Hi Sifus,
Quick question. i will be sending my E46 (M43) to replace a leaking Flywheel Oil seal.
The cost of the Oil seal is cheap but the workmanship will be prob RM 300 to 500.
Pls advise from your experience, when you drop your gearbox, what other seals, o ring etc which one should consider changing at the same time. Hope fully, by doing this , we will be able to save cost and time .
Thanks for your inputs, if any.
OldmanBM
For my E46 - M54 engine, I also change the oil seal for the gearbox/torque converter since both were leaking.
