E46 - "Beep" before starting engine
leonard
Hi All,Just curious... When I switch on the key there is this "beep" sound which come on prior to cranking. What is this beep sound for ?? What difference does it make if u crank before and after the beep sound stops ?? Is there such sound with your rides ??Rgds,
I've gotten that a few times also but have never figured what it was beeping about.
never heard got sound also.....
if the car still can start, fark it la.... nevermind one la.
Originally posted by The Necessary@Aug 3 2005, 06:42 PM
I think that's just its way of saying "hi". You know, soul.
I'm so..... touched....
my ride is so called "Japan spec" which comes with this beep sound. I am not sure whether local or "UK" spec. are having this "feature" ?? or some other "Japan spec" oso dont have this ??!!
Mine is local AB.
Looks like it follows the wannabe trend too.
Well, the Japanese, you know, are a more polite society than most. So, well, maybe they've programmed all Jap Spec BMWs to say "hi".
Mine local AB model. Maybe not as polite as Japs :rofl:
If the beep is not affecting your ride in any way . . . just forget & live with it lah brother.
Spidey - tend to agree with u lah ....... its not advisable to be a perfectionist or being so meticulous... i think ..... Cheers!
sure that indicating "i am sick, help me"??
Didn't hear any beep for local CKD.
Mine's a Jap specs. Before the car starts, it beeps a couple of times. I'm very sure mine's the seatbelt indicator. If seatbelt is engaged, no beep sound and vice versa.
Beep ? No beep on normal starts.
Beep is heard when there is a fault e.g. light bulb failure, low washer water, low petrol, etc ... it accompanied by some light on the dash
mine ckd also.. turning, before crank, got beep = hi.. when switch off, also got beep=bye.. :D
I'm starting to wonder if it's a configurable setting at the on board computer....
START_UP_DING_SOUND_THING = 1;
:yahoo:
