planta
- Sep 17, 2007
- 508
On last Sunday night 11pm we got a distress call to help an E46 328 driver in distress due to his car overheated. Owner balik kampung and wanted to go back home south but had to change his plan to fly back south next day.2001 E46 328 - perghhh powerful car... stock condition, even the sport rims
IssuesSecondary Thermostat jammed causing the expansion tank to burst.
The culprit was the secondary Thermostat under the expansion tank
Noticed that the radiator was in bad condition, leaking too. The car had red color coolant. Don't want to say what brand lah which we suspect, later kena saman in court. It is said that some coolant especially the brand with red color coolant is hard on aluminium radiators. So I think better use BMW coolant fo BWMs la.Due to overheat, one of the water hose over expanded (bengkak) and torn. Luckily only 1 water hose. If the whole set... ribu bang...
New radiator
Things changed.1 water hose, secondary thermostat, expansion tank, coolant, radiator and radiator cap.So guys, do check your coolant usage and change your secondary thermostat if it is already a few years old.Hope the sharing helps.planta
