e46 325i camber settings?
its normal to have -1 to -2 degree camber when lowering. Important thing is that you dont have totally different camber left n right...eg -1.5 and -.3 as the car will be harder to track on a straight line and will pull to the side with less camber. most alignment shops will try to adjust this by having positive toe in but this can wear out your tyres quick
vobs;414036 said:
recently got to know that my front have way too much negative....about -2.5......
Dear sifus, anyone know how to fix it back to normal. Tenk u!
Need help
if its the front ...use camber plates. for the rear you need the adjustable lower control arm.
Anyone know where to buy those adjustable camber plates in Malaysia? how much roughly?
Thanks
tq 4 d thread bro, mine is also lookin for alignment/tyre shop prefer bangi area, before kena sembelih reccomd pls
Still no one knows how? 2.5 negative need to be adjusted back to normal, already change bush, lower arm, still like that? how? why? please help.....
Ok after many months of searching......i guess the only two thing I can do is
1) Camber plate with +/- adjustment
2) change back to ori suspension
Those who have the same prob, go try the two and let me know...
