my lh rear window decided to quit working.the window not moving at all but can hear the motor running.opened it up and found the small metal thingy that clamps onto the cable,is broken.removed the regulator (one 10mm bolt at the bottom one 10mm star bolt at the top - quite tricky this) from the door and glued using two part metal epoxy.working fine now.....
