bimmerholic
- Apr 9, 2009
- 2,475
- 38
Guys, has anyone replaced the mentioned item before?Mine's showing some sign of sludge deposit at the oil separator. I ran a search through the forum and came across a similar problem. Only diff is his car is an E46. http://www.bmwclubmalaysia.com/forums/showthread.php?t=12297&highlight=oil+separatorand i'm not sure if mine's gonna turn out to look something like his on the inside. But i notice minor misfiring during idle at times. But there is no problem whatsoever while driving. The following is the part number and the item (2); same as pressure regulating valve:http://www.realoem.com/bmw/showparts.do?model=DD42&mospid=47539&btnr=11_1487&hg=11&fg=15My question is, how much does this item costs? labor? and is it serviceable instead of changing the unit? Is there any interval for servicing/replacing this item or only as and when you see gunk leaking?Thanks very much in advance.
