E32 730iL Poor Acceleration.
AAM
How can i improve my E32 730iL ( Auto ) acceleration /pick-up.Can i just change the rear diff to a smaller no./ratio ( is it lower or higher ratio we call them ? )Thanks.:top:p/s : running 100kph at 2200 rpm.
Th3 M30B30 is rather a bullet proof engine and quite torquey. If the acceleration is slow.... wondering what are You benchmarking it with. it whoudl do a 0-100 around 10-12. if it is that range.. then you should not do anything to it. otherwise... you should check your vacuum hoses and timing sensors. both the cams and the crank. Sometimes the vacuum hoses leak and not giving enough vacuum to advance the timing and thats the main reason M30 loosses its power. otherwise.. like i said before.. M30 is bullet proof.
Regards
Alan.
AAM.. kalau nak laju macam i punye V8... kena transpalnt a M60 lah.. LOL
check condition of your spark plug cables.. that could be one of the culprits.
come on kgb.. not that kind of conversion... keep the UDM mark.. and not jap-erdise it..
i seriously agree, no offense to any bros/sifus out there who have UDMs with jap hearts...im just a purist :top:
kgb;509798 said:
change engine lah!
May i suggest 2jz?!
I may just do that ............but i am a purist for the last 20 yrs or so........and still is.......he....he....hee....
If all things fail, I may embark on a project.........transplant with 3.5L or 4.0L V8 !
Just need that xtra ooomph at traffic lights.......!!!!!:top::listen: :listen: :top:
you do that, and i'll do 2jz. We can than compare the oomph from the traffic lights and road tax hehehehehhe
2jz cannot lah........pakcik WV, ah chong Datsun , samy Toyata KE, cikgu mat pencen Volvo can lah........bob souped up Kancil ? ......... c 1st the front got inter cooler or not..........
Update: Issue taken care off. I am happy with the take-off acceleration - its already 2 weeks, no problem.
A lot of thanks to alantiong, mizhan and others.
Thanks.:top:
in this order
1) change engine oil&filter, check air filter, check/clean/change spark plugs ,...also adjust throttle cable,
2) check/change dist cap & rotor, inspect plug wires, check/adjust CO2 level, adjust valves..
