E30 Nissan R33 caliper upgrade conversion
MazToy
Hi, I have an E30 with SR20DET conversion making around 200rwkw. I've fitted slotted discs all round and have a set of 4 piston R33 brake calipers for the front. The stock Nissan (180SX) brake master cylinder has also been used from the half cut.Has anyone done this conversion before? I'd like to know what problems I may encounter before I start. I already appreciate the wheels need to have a large clearance for the caliper (still 4 stud).If anyone has this conversion I'd really like to take a look or maybe be sent some pics if available showing how they're mounted.Cheers,Bill
Normally the caliper will be fitted with it own disc rotor. If you are using different disc, make sure its diameter size is not much different and it thickness is same. R33 is using twin disc rotor but E30 is single.
sample pic, E30 using S14 4pot caliper, convert to 5 stud 114.3
