Hi, does anyone seen these problems before as described below.
I have verified that all 4 wheel speed sensor are giving consistent identical readout within a monitoring period of 5mins. Wondering what could be at fault here as there are various codes displayed.
Vehicle: 2014 BMW F30 316 N13
Fault Displayed On Dash
1. Drivetrain
2. Driving Stabilization
3. Flat Tyre Monitor (RPA) Failure
Fault Displayed with OBD- ERROR Memory
Digital Motor Electronics
107A81: THROTTLE VALVE, CLOSING SPRING TEST: MALFUNCTION
100101: THROTTLE VALVE, FUNCTION: PERMANENTLY CLAMPED
107A70: THROTTLE VALVE, ACTIVATION: SHORT CIRCUIT
107A50: THROTTLE VALVE: EMERGENCY RUNNING ACTIVE
100A04: THROTTLE DAMPER, THROTTLE POTENTIOMETER 1 AND 2: DOUBLE FAULT
1C0101: ENGINE OIL PRESSURE CONTROL, PLAUSIBILITY, STATIC: PRESSURE TOO HIGH
1C2001: ENGINE OIL PUMP: PRESSURE TOO HIGH
100201: THROTTLE VALVE, FUNCTION: STIFF, TOO SLOW
100001: THROTTLE VALVE, FUNCTION: TEMPORARILY STUCK
Integrated Chassis Management
D02D58: SIGNAL ERROR (WHEEL TORQUE DRIVE 1, ID: WMOM_DRV_1) - QUALIFIER
Dynamic Stability Control
4809AB: GLOBAL POWER SUPPLY - UNDERVOLTAGE EXTERNAL
D36D58: SIGNAL ERROR (WHEEL TORQUE DRIVE 1, ID: WMOM_DRV_1) - QUALIFIER
D35A57: SIGNAL ERROR (LONGITUDINAL ACCELERATION CENTER OF GRAVITY, ID:
ACLNX_MASSCNTR) – QUALIFIER
Fault Displayed with OBD- INFO Memory
Central Gateway Module
101008: UNRESOLVABLE AMBIGUOUS ROUTING - SG NOT IN THE SVT TARGET TABLE
100600: FLEXRAY PROTOCOL STARTUP TIME IS TOO HIGH
100104: HW WECKGRUND ZGW
100203: DM SOFTWARE ERROR INFO WARNING
100204: MESSAGE MONITORING: SYSTEM CONTEXT SIGNAL FAILED
231501: ERROR MEMORY ENTRY: TRANSMIT BUFFER FULL
480115: DRIVING DYNAMICS SWITCH - FORCED ACTIVATION DSC
482651: FLOATING ANGLE ESTIMATOR - INPUTS NOT VALID SBS
482656: FLOATING ANGLE ESTIMATOR - INTERNAL DEGRADATION DUE TO SBS
4827B3: INTERNAL CONTROL UNIT - UNDERVOLTAGE AT TERMINAL 30
Front Electronic Module
804029: NVM_QUEUE_EEPROM
Instrument Panel Control Unit
E12C2F: INTERFACE HU (ACKNOWLEDGMENT REQUEST COMBINATION, 0X172):
SIGNAL FAULTY
E12C30: INTERFACE HU (STATUS SERVICE CALL TELEX, 0X30F): SIGNAL FAULTY
Integrated Automatic Heating / Air Conditioning System
078004: NVM_E_INTEGRITY_FAILED
1. Drivetrain
SIGNAL FAULTY
