evilnickwong
- Mar 10, 2006
- 689
Most of us with E30s probably have faced the issue where the AC vents no longer hold their vertical position. Every time you drive over the tiniest of bumps, it just falls down and ends up freezing your legs.So here's a fix I read about online (can't remember where) which worked well for me.First, remove the vent unit from the dashboard. To do this:1) Turn the vent so it faces as far down as possible.2) Stick a flat head screwdriver between the top of the vent and the dashboard and pry the vent out. Be gentle, last thing you want it to go shopping at BavAuto for new vents. 3) With abit of effort, the vent should snap out of place on each side. Once that happens, ease it out of the dashboard.Now, get a brush and soap and clean the heck out of your (probably dirty) vents. Then, protect them with some good dashboard shine.
Next you need to add something so that there is greater friction between the side of the vents and the dashboard socket in which it resides. There are 2 things I used, one is velour (the green stuff you see in these pictures) and the other thing you can use is velcro (the soft side, not the pokey side). Use whichever is necessary as velour is not so thick. Stick it on the sides of the vents like so:
Once you're done, just insert them back in to the socket.You can see here that there are two tabs on which the vent "hooks" on to.
The technique to putting them back in is to angle the vents downward just like when it came out, then push in firmly until they snap into place. You'll get a better idea when you look at the shape of the hook on the side of the vents. Enjoy your now, snug and firm fitting vents:
And never ever have to hear your passengers complain about vents falling down again.
