DIY - AUX cable for BMW Business Radio/CD
anaksarawak
Official Member
I am hoping to have some club guest or OM to do this together during one of our TT.Let's get started.
1. This was male on both end and I just cut one side.
2. Close up
3. Some people might wonder what this is.
This is a cable that I found from my old computer I was about to throw away. This pin connects to motherboard for power switch, reset switch, hdd led, power led, etc.
Do not cut the other end of this cable, just pull the pins out. It will help you to solder it.
4. See? It is so much easier to connect them to solder it.
5. 3 small and 1 big heat shrink tube.
6. Ok. It is done.
7. From HU, pin 8,9(left,right or right,left don't care too much.
) and pin 4(ground) need to be connected.
You will be surprised how well it fits.
8. Finished
http://www.jpwearmfg.com/x/aux/10.jpg
Total cost $0. Because I found everthing I need at home and it works great. http://forum.e46fanatics.com/attachment.php?attachmentid=84802&d=1089824812
red/black(sound left/right) goes into pin 8/9 and
yellow(grounding) into pin 4.
if you take the deck out and look close into it, it has numbers.
attachment.php
images
Bro anaksarawak, need your help pls. I just bought a new player Sony for my E34. The guys fixed it. Sounds OK. But i feel i need to change the rear speakers plus the base boom. Also the wires too. But i am very nervous to allow the shop to do it, because they dont seems to have experience in opening an E34. You know la old model. Also i am very worried when these people just do short cut work, than later all goes haywire. So can you recommend me of someone who knows an E34 very well and can do these fixes for me. Much appreciated bro.
Bro, E34 is very nice car to work on. Good sound insulation and plenty of space. Sony are not known for their sound quality however suffix if we listen to radio / mp3 most of time.
For a good improvement, you will have to remove the factory amp/crossover and use a new 4 x 60W (or more) RMS to drive a set of component system speakers.
2 way components speakers are a set of 2 tweeters and 2 woofers, used in conjunction with a passive crossover. The passive crossover takes the signal from the amp and direct it to the correct speakers: tweeter signal and woofer signal.
Let's install a set of component speakers. Put the maximum money on the front speakers, the rear speakers are just to "fill in" so you should use a pair of coax if you want. It is the same procedure for just changing speakers. The bigger speakers you can use without major modification are 6.5", they need a little bit of modification for the front and rear. I will suggest to run 5.25" front and 6.5" rear component system Naka/Infinity/MBquad.
[SIZE=+1]Procedure[/SIZE]
Front speakers:
1. Front kick panels are easy, turn the clips 1/4 of a turn with a hex wrench. There are several small trim clips that you can remove with a screwdriver. Removing these will provide easy access to the speaker.
2. There is two way to connect the new tweeters: in the original location, remove the old one (could be hard to pull out but they will come) then glue the new one in place.
Or use the stock location of the midrange in the dashboard.
Rear speakers:
1. The rear speakers are harder. You need to use a needle noise pliers for some of the screws and a small Philips screwdriver to remove the cover. The rear speakers are into a bowl shaped black plastic. You don't need to remove the rear shelf, except if you use speakers bigger than 6.5".
3. Connect the factory wires to the speakers. Stop here if you are just changing the speakers.
For huge speakers: you've got to remove the shelf and the C pillar trim pieces too. Start by pulling up on the front of the seat part of the back seat. Then pull up and out to remove the seat back. You should see several trim fasteners holding the rear shelf in place remove those. The rear shelf should slide out. To remove the C pillar trim panels just grab them and gently pull them out. They're held in by tension fasteners. WARNING: the C pillar trim pieces area a hell to get back in place.
Passive crossover for new amplifier installation.
If you changed your whole system (bye, bye old oem amp) and installed a new amp, you need to install the passive crossover included with your component speakers.
The best location for the passive crossovers is in the trunk, at the fare back, behind the carpeting, you will find an area that is deeper than the rest of the trunk. This is the ideal spot for the two (if you have coax at the rear) or four passive crossovers. Ideal because the wiring harness of the stereo is right there. Check the wiring to connect the wires to the crossovers.
Just use double sided tape and place them in their new location.
ORI SPEAKERS
picture.php
Smike, go and talk with erica34, he has a modded e34 with very nice audio setup.
Front speakers:
Rear speakers:
ORI SPEAKERS
picture.php
Bro thanks a lot. For the valuable information and the know how of how to go about doing it. Again thank you so much for this. Once i got it done, definitely i need to buy you a drink bro. :cheers:
I will but unfortunately I dont know him. Hopefully i would be able to meet him in one of the TT gatherings. Thanks again. :cheers:
Just PM him and arrange meet up..He is a nice talking guy.
I think he is more than happy to share with u about his setup.
