..cruise control..
Ecc0
Associate Member
..i have 'discovered' that my Z4M has cruise control, whats great..i really love it..however, i was unable to find a way how to activate it during drive..i couldnt find any info online, except instructions for retrofitting in older Z4's .. do you guys have such information?? Im really curious how its working considering that car is with manual gearbox..
My S62 (and all others as well, I believe) has it too, and it works.
And yes, all S62 are ///Manual.
Its an incredibly usefull system to use when you're going past an area with speed cameras.
With manual gearboxes, the system will have a switch on both the clutch and gearbox. It will behave the same way as the switch on the brake pedal and will immediately disengage the cruise control if you disconnected the drive or shifted into neutral.
Come to think of it, I never did test shifting it into too high a gear and engaging the system. It should have some safety cut off I believe.
