Cracking the Code
kevster30
Cracking the Codeby CircusCow Engines Code Cyls Capacity ValvesM10 4 1.6,1.8,2.0 8M40 4 1.6,1.8 8M42 4 1.8 16S14 4 2.0,2.3,2.5 16M43 4 1.8 8M44 4 1.9 16M41 (Diesel) 4 1.7 8M20 6 2.0,2.3,2.5,2.7 12M30 6 2.5,2.8,3.0,3.2 123.4,3.5,3.5tM50 6 2.0,2.5 24M70 6 5.0 24S36 6 3.6 24M88 6 3.5 24M52 6 2.0,2.5,2.8 24S50/B32 6 2.9(E36 M3) 24S50/B30 6 3.2(E36 M3) 24M21(Diesel) 6 2.4 12M51(Diesel) 6 2.5 12M57(Diesel) 6 3.0 24M60 V8 3.0,4.0 32M62 V8 3.5,4.0,4.4 32M73 V12 5.4 24S70 V12 5.6 24S70/2 V12 6.1 48--------------------------------------------------------------------------------Badgingi Fuel injectedCSi Coupe Sports injectedCi Coupe injected ('70s)Ci E46 3 series convertibletd Turbo dieseltds Turbo diesel with intercoolerd Common rail BMW diesel modelse 'eta' economy engine in the 525eiX Four-wheel driveXi Four-wheel driveSE Special EquipmentM3 Motorsport 3-SeriesM5 Motorsport 5-SeriesM6 Motorsport 6-Series, correctly known as the M635CSiB3 Alpina 3 SeriesB10 Alpina 5 SeriesB12 Alpina 7 Series and 8 SeriesM-Technic Motorsport styling, suspensionBaur E21/E30 3-Series CabrioletL Long wheelbaseti 3-Series Compact--------------------------------------------------------------------------------Cars3-Series E21 3-Series (1975-1982)E30 3-Series from 1983E30/5 3-Series TouringE30/16 3-Series with four-wheel driveE36 3-Series from 1991E36/2 3-Series CoupeE36/5 3-Series Compact from 1994E36/3 3-Series Touring from 1995 (with M52 engines)E46 Current 3-Series from 19985-SeriesE12 5-Series 1972 onE28 5-Series from 1981E34 5-Series from 1998E34/16 5-Series with four-wheel driveE39 5-Series from 1996E60 5-Series from 20037-SeriesE23 7-Series from 1977E32 7-Series from 1987E32/2 7-Series, long wheelbase (iL) versionE38 7-Series from 1994E65 Current 7-SeriesE66 Current 7-Series long wheelbase (Li) versionCoupesE24 6-Series Coupe 1976-1989E31 8-Series CoupeZ CarsZ1 roadsterE36/5 Z3 roadsterSAV E53 X5--------------------------------------------------------------------------------TechnologySteptronic 'Manual' mode on BMW automatic gearboxesSwitch-tronic Alpina 'manual' mode for automatics using steering wheel shift buttonsShift-Tronic Alpina's clutchless manual gearboxVANOS BMW's variable valve timing systemDME Digital Motor ElectronicsCBC Cornering Brake ControlASC+T Automatic Stability Control and Traction ControlADP Active Driving PackageARS Active Rollover Safety SystemDBC Dynamic Brake ControlAGS Adaptive Gearbox SystemEDC Electronic Damper ControlEWS BMW's electronic immobiliser systemPDC Park Distance ControliDrive Central menu sys
Erm... do u have the crack for reading chassis number ??? thank you...
How to have the electronics of E36 checked? Where we can do that? I am lost here as I fairly new in KL. Everything here are expensive compare to Kuching. A car check in Kuching is FREE but here most workshop charge.
Anyplace I can send the car I might soon to own to have a health check? Beside Puspakom la.
