BlackE90
New Member
- May 19, 2007
- 1,686
Superb 'Cool Carbon' Brakes Pads for OE pads replacements are available now. Excellent reviews on stopping capability and heat range, that guarantees superior performance to OE (see below for more info). Street Performance/Track Tuned (S/T) - This compound is a higher friction level than OE, with much better torque and stopping capability. It is very stable, both cold and hot to temperatures exceeding 600 C (1112F), due to a special “hollow” ceramic structure that exhibits excellent heat dissipation characteristics. Stainless steel noise shims, bonded to what is already a very quiet formula, ensure virtually no noise under all driving conditions. Improved pedal feel and significantly reduced dust can be expected.S/T brake pad compound features are:1- Excellent initial bite2- Consistent torque3- Excellent stopping ability & temperature stability4- Very good fade resistance5- Long life, rotor friendly6- Low/no dust7- Virtually without noise;8- Excellent for daily street use and with very good track performance.The Cool CarbonTM High Performance Brake Pads are manufactured in state-of-the-art facilities using the “True Positive Molding” process. This process ensures that the brake pads are extremely consistent from pad to pad. The pads are scorched during the manufacturing process to accelerate the bedding procedure.Any feedbacks from current users? I have bought a set for the front & will install them in the next few days.
