Hi, ALL
Got a M50B20 engine come with original German ZF (5HP18) 5 Automatic speed gearbox including long shaft, axle etc for sale.
Has spent thousand of dollars to restore the engine to it's prime performance viz new MAF, starter motor, re-conditioned alternator, replaced new gasket for cam cover, intake manifold & throttle body and fully clean and service.
Will also giving the radiator, ATF inter-cooler, ABS & brake servo pump, etc if require.
Regularly service with use of high grade engine oil every 10k , flush & replace ATF oil every 20k.
This will be ideal for those 316/318 owner looking for upgrade
Looking at $6.5k (Negotiable):rock:
Pls pm me if keen
