ContinentalGT
Official Member
- Mar 7, 2016
- 78
Hi everyone. I am driving E90. The ABS/DSC/FTM/HSA failure error came out last year and i sent to a shop in USJ for rebuild on May 2016 as per recommended by most of the BMW owners here. Throughout the year, the error come back a few times and I also sent back to the workshop for 4 to 5 times. Now, more than 1 year, the problem starts re-occuring again which makes me wonder if this ABS pump problem is really that problematic to get a permanent solution?
But this time, my car will have judder when at low speed and also during low speed breaking(say below 30kmh) but intermittent which i did not have this issue last year.
BTW, i am confused when some ppl mention it is the module causing the problem but not pump whereas some said it is the pump.
The error code is 5df0 and 5df1 which clearly stated hydrualic motor and pump failure.
Can anyone share your experience on your ABS Pump/module rebuild and did it last after the first rebuild? how long have it been?
