Changing Tail Light Bulb
tongsatriani
Hello Sifus,Is it changing/replacing as easy as ABC, 123, plug & play??The reason I asked:1. Left side no light; so I use the right on the left for a "bulb test".2. The right ones is not working on the left; so I assume it's wiring problem.3. When I reinstate the right; NO light! but it was working seconds ago!4. Nope! The right bulb is not blown. Still can see the filament inline.How???:confused::confused:
weird, i recommend u to drive to brother's or dragon sound or similar accessories shop to get the bulb, about RM2-4/bulb. from there u can know is it bulb problem or wiring problem, if wiring problem, those guys at the accessories will be able to fix it as well.
tongsatriani said:
Hello Sifus,
The reason I asked:
its just a contact problem la... e34 tail/brake lights are liddat 1....
