Changing rear tyres from 255-40-17 to 225-45-17
wz3k
Hi Guys,I have a 320d and at 34,000km my rear tyres almost botak already. Now I have a staggered config with 225-45-17 in the front and 255-40-17 at the back.Is it technically possible for me to change the rear from 255-45-17 to 225-45-17? I understand that 320i have this config but I don't know if my 320d have the same rim size at the back and if it will fit. Reason I'm thinking about this is the $$$thanks
wz3k;779930 said:
Hi Guys,
thanks
Bro the stock 320d rims are staggered in size.
The width of our rims are 8.5 front and 9.5 rears.
So if u go to 225 all around the rear tyres will have that stretched look
wz3k;779930 said:
Hi Guys,
thanks
GT Radial Campiro HPY or NEXEN 8000 245 40/45 17 are not that expensive
thanks bro.. are you still using RFT till now or change to normal tyres already? thanks
i am on nonRFT Contis on 19" BC Forged wheels now :rock:
get the rims of 320i? i wonder what are the differences between staggered and normal, handling wise, also noise comfort etc
320d has much torque that the 320i, therefore a 255 at rear for the RWD to minimise the possibility of oversteer. I think a 225 at rear for 320d will go botak much faster than a 255 due to less road contacting surface.
For handling wise, noise and etc, you may have a better understanding from this article.
Effects of Upsized Wheels and Tires Tested
http://www.caranddriver.com/features/effects-of-upsized-wheels-and-tires-tested
