Changing Absorbers Advice
jeffreychung
Hi all, my e46 both front and back absorbers died .. Should i change to stock standard or adjustable ? Brand for adjustable and the rough price would be appriciated, cuz i dont know much about the absorbers ..Thanks
jeffreychung;570743 said:
stock vs adjustable .. may i know the difference ??
sifu pls let me know
stock = well..ur just stuck with stock..if wanna use stock i recommend get M-Sport suspension..
adjustables = got fully & semi adjustables..fully u can set ur stiffness level and height..semi only can adjust stiffness but not height (or vice versa?)..also some only allow to adjust front sets only..more expensive ones can adjust both front & rear, stiffness & height..recommend to get KW
if got budget better go for adjustables / coilovers..can tune it to suit ur comfort + performance level..else go with the normal Bilstein + Eibach combo..or H&R etc..
i'm not a sifu..but just would like to share my knowledge n little experience..:) happy hunting..
Hi, I have an e46 325i ori Msport and its due for absorber change. Do you know what's the ori absorber brand that compliments with msport suspension
SACHS Advantage
the msport absorber only comes with the offocial msport version of the car series. The 4 potter may have different abs than the 6 potter due to the difference in front end weight.
That's meant 4 potters absorber cant use in 6 potters car ? or are they using same absorber but different spring ? need to change my absorber, some shop say using same absorber.
nope they are different. the damping is different. if you use the 4 potter abs on the 6 potter, the front end is gonna sit lower with different sag. your abs won't last as the seal will go bust due to the extra dynamic forces from a heavier unsprung weight.
Bro the abs 4 potters and 6 are different mine car was same as yours Jpn spec 6 potter right?
I get mine from BA brand SACHS $315/PC last Jun/10.
Just changed my 4 absorbers and mounting to BOGE by ZF. Cost me RM1.7k. E46 318i
dvng;585331 said:
your absorber won't last as the seal will go bust due to the extra dynamic forces from a heavier unsprung weight.
I believe you mean sprung weight. :)
unsprung weight only comes from rims,tires,brake pads, brake disc, and etc.
since nothing has change, unsprung weight should remain the same.
But due to springs, and absorbers are different, your car is sitting lower, which going to transfer weight to front (or rear).
This alter the travel distance/speed for the absorber and springs(up and down), which will shorten your life for your absorber.
:) Cheers
