Bimshop Singapore
Club Vendor
- Dec 7, 2012
- 2,520
- 63
t2ribena;827035 said:Meaning all stock bmw without this right scoop is taking in warm air for the intake?
The air is hitting the scoop at right angle, does this not create turbulence that disturbs the intake input?
Bimshop Singapore;827072 said:nope, the normal air intakes are not taking in warm air, just less air.
the air intake is located parallel to the car body so air just flows by and some air gets in.
with the scoops, it is helping to better direct air to go in.
the design of the scoops is a straightforward one, not those with cylindrical design so basically airflow is flowing in smoothly without much turbulence.
it would more of a ram-air effect using the scoops.
t2ribena;827102 said:I am wondering why BMW engineer did not realize the benefit of such scoops and install it as stock assembly as it would be easy for them to get it implemented. This must be something beyond their know-how...
Do you have any data to support the less air before and more air with scoop? i assume with more air into the intake, the power output should be higher right? any dyno data to support this design?
i was asking on the air hitting the scoop and create turbulence because when for example the car is travelling at 120kmh, assuming the air is stagnant, the air would then hit the scoop at a speed of 120kmh at right angle. the air would certainly be reflected back out creating drag...wouldn't this cause less air into the intake...as you go faster the worse it gets...which is diff from ram air effect...
rattlesnake1982;827116 said:This calls for a dyno pre and post installation of these air scoops
To end this argument
t2ribena;827261 said:I am surprise that my inquiry and discussion on this scoop has now evolved into why bmw not make better coilover or fixing rusted seat...
Well as the seller claim that this scoop improve engine efficiency and fc, i think it is fair for me to ask and clarify and also makes me wonder why bmw engineer does not implement this scoop when they are pursuing better engine efficiency and fc which would allow them to achieve their goal of reducing polution and at the same time pushing more output...
To liken this discussion to better coilover and fixing rusted seat is irrelevent for a simple fact that better coilover and non-rusted seat does not promote higher vehicle efficiency and fc to the engine...
Anyway, since the discussion has gone south, then i shall let it be...
TQ
Nevertheless your ride looks great bro!Val101;827297 said:Hello! No one is talking about Coilovers here nor liking this discussion to better Coilovers :thefinger:, but i just made an example about the Rusted Seat which almost all countries are complaining about on the F30's and BMW haven't still yet 100% resolved it because you stated that why BMW Engineer did not realize the benefit of such Scoops!:motz:
It will be the right Decision for you to let this discussion be :top: otherwise it Might also go far NORTH!!!:motz::motz::motz:
t2ribena;827325 said:Great mentality...very good for the club forum...
