stephen
- Dec 8, 2004
- 221
Check it out at http://www.bostonacoustics.com/car/car_pro...&product_id=296 Seems KF Audio recently installed on a E46 coupe without modifications to the door. The good thing about this is that it is 6.5" woofer and not like my Focal Slims of 5" only. So the bass would be better for sure. Only problem is the price .... i heard > RM2k !!Speaker Size6-1/2"Rated RMS Power Handling125 wattsNominal Impedance3 ohmFrequency Response (±3dB in car)50Hz-22kHzMounting Cutout Diameter5" (127mm)Mounting Depth2-3/8" (60mm)Mounting Depth with Spacer2-1/16" (52mm)System Type2-wayCompetition 2-way car component system :6½" copolymer cone woofer with neodymium magnet 1½-inch voice coil RadiaVent® cooling and Twinstage™ heat sink for increased power handling Cast aluminum woofer basket 1" Type-M2 anodized alloy dome tweeter with slim AMD™ Separable and dockable crossovers VariMount™ adapter rings allow for fast installation Axis-, flush-, and angle-mount tweeter mounting kit
