Just a small question:-Boot unlockI always have to open my boot for security check. The problem is that most of the security guard do not know where is the boot switch (which is located under the lifter). So in most case, I have to manually open the boot from the inside of the car. My problem is the "boot open" switch is located just above the front bonnet lever. I cant seem to "feel" this switch unless I open the door and duck down to see the location of the switch. So my question is how you overcome this problem other than relocating this switch higher. BTW, I have try to use the "bonnet open" switch on the key but if it does not seem to work when the key is inserted in the ignition slot. It work fine when I outside the car. Appreciate any idea?? Central LockingAnother thing is that I notice that all doors is automatically locked when the car is moving. However, when I stop the car and engine, the door did not unlock. I noticed even my friend proton car door unlock whenever he off the engine. So the question is can the door control module be program to open all doors or driver door when the engine if off. cheers.. Sorry, family is complaining why door cannot unlock...
