astroboy;310269 said:
The later vehicles are mostly running one all-in-one electric fan, E90 also the same and somemore canggih, it has an inverter technology, if not wrong.
Start engine, fan no turn.
When engine heat up, fan turn.
When aircond on, compressor cut in, fan turn faster. Compressor cut out, fan turn slower.
But one evening, I off engine, pull out the key, fan still running. I thought engine too hot and certain JDM has this feature.. waited few minutes, fan still running... something is not right. Restart the engine, on aircond, then kill everything.. This time, fan stops.. :stupid:
I think everything is taken care of.. good enough for me.
More electric fans draw more electric current, alternator works harder to recharge the battery, engine load heavier, FC higher, battery life span shorter, alternator life span shorter..bla..bla..bla..
We can debate until the cow comes home but I am happy with status quo.
This reminds me of certain race car wannabe lifted their bonnet with a gap near the windscreen thinking hot air will release faster when can on the move.. :stupid:
you want to protect your alternator??
but eletric fuel pump run all the time, electric window....
you should check the entire car wiring (E90 model wiring), some time the
factory worker(tire)/robot(wrong program) connect wrong wiring terminal
and cause certain short circuit. the short circuit did not put the car
on flame, cannot detect by OBD2 DIAG
, drain battery,
loosing horse power, damaging alternator, altering the DME/ECU,
improper spark,.....
To detect the short circuit, check the battery current drain rate
with everything off include the trunk light (off by press contact switch).
the current drain should not exceed 100mA (for my car).
my car currently at 50mA no alarm. (installing new alarm system)
my car really had the wrongly connect wire.... had solved,
1. the fuel filler door actuator (only can close with alarm)
2. the car alarm system (? wire link with a wire go to Climate control module)
3. the stereo hi-fi (+ go to memory line ?)
4. the DLC wire (2 DLC wire goes into dash board for ?)
once the short circuit solved, the car 0-100km/h in 4-6 second,
the car can do driff 180deg turn, just like the transpoter....:rock:
