Ojwong
Official Member
- Jan 28, 2012
- 162
Some useful info to share. Source: www.endtuning.comMany Modern BMWs now include a full range Check Control System. The early BMW Check Control System involved monitoring the resistance of the vehicle lighting, and could report a blown bulb instantly. Corrosion at the bulb socket may also trigger error warnings, so remember to check the bulb itself along with it's operation. As the vehicle electrical system became more complex, more systems were added into Check Control, from simple door warnings, to a far more integrated system used today. With a variety of Data Buses used, fault information in individual modules could be passed to other systems that may depend on them. This allows a Check Control System to be added into the Data Bus, which is able to show faults to the driver. Although still not as useful as full diagnostics, it does represent a great leap in fault handling, compared to previous "Check Engine" warnings. How To Access Check Control Messages Flick the BC (Board Computer) Stalk up or down until CHECK CONTROL appears, then press the BC button on the end of the stalk. Flick up or down to scroll through multiple messages. On a particular message, Press and hold the BC button for approx. 2 secs. This will show the CCID code. To Exit the system, press the BC button again. The codes listed below are grouped into the modules that created them, but there will only be one number for a fault over the entire system. This means the if you see CC-35 (DSC Failure), There is only one fault that will cause it, and seperate modules will not share a number. Press Ctrl+F to search within the page to find your code. Yellow lights serve to draw your attention to an upcoming service, or a sporadic fault which may require extra care with regards to the system that triggered it, and something to be looked at closer. Red lights suggest a failure in a system which may require immediate attention. Common symbols include Service reminders, Inspection reminders (visible in the picture above), or a pictogram of the system which has a fault. A double S symbol, § indicates a service station inspection, such as an MOT test or other yearly inspection.BMW CCID Code ListActive Cruise ControlACC 158 Active Cruise Control Disabled, Sensor ErrorACC 238 Active Cruise Control Disabled, Hill DescentACC 441 Cruise Control DeactivatedACC 442 Vehicle may Roll AwayACC 443 Vehicle Rolling AwayACC 483 Active Cruise Control Temporarily DisabledCrash Safety ModuleACSM 76 Crash Safety ModuleACSM 434 Seat Calibration RequiredActive Front SteeringAFS 70 Servotronic FailedAFS 273 Active Steering FaultAFS 321 Active Steering DeactivatedTrailer ModuleAHM 4 Trailer Parking Light LeftAHM 5 Trailer Parking Light RightAHM 6 Trailer Indicator LeftAHM 7 Trailer Indicator RightAHM 8 Trailer Brake LightsAHM 9 Trailer Fog LightAHM 75 Trailer Electrics FailedAHM 90 Trailer Reverse LightAHM 403 Trailer Rear Light/Numberplate LightAHM 404 Trailer Left Indicator/Brake LightAHM 405 Trailer Right Indicator/Brake LightAHM 406 Trailer Electric Brake FailedAHM 423 Trailer Coupling LockAHM 449 Trailer Coupling Electrics FailedDynamic DriveARS 10 ARS Roll MalfunctionARS 11 Steering MalfunctionARS 12 Dynamic Drive FailedARS 204 Dynamic Drive DisabledCar Access SystemCAS 14 Door Open F/RCAS 15 Door Open F/LCAS 16 Door Open R/LCAS 17 Door Open R/RCAS 18 Bonnet openCAS 19 Boot openCAS 21 Ignition Problem, Depress Brake to StartCAS 22 Starter Problem, Engine cannot RestartCAS 38 Wrong Remote KeyCAS 40 Press Brake to StartCAS 65 Change Key, Key Battery LowCAS 66 Remote Control/Key FaultCAS 67 Remote Control/Key Battery DischargedCAS 68 Remote Key Stationary Function Battery LowCAS 186 ELV Steering Lock Fault. Engine cannot be restartedCAS 187 ELV Steering Lock Active. Move Steering Wheel to RestartCAS 205 Remote Key not PresentCAS 206 Engine Start on next PressCAS 208 Comfort Access DeactivatedCAS 209 Remote Key in Vehicle, Locking not possibleCAS 217 No Remote ControlCAS 303 Depress Clutch to StartCAS 335 Ignition Switched OnCAS 347 Position R/N/D Not PossibleCAS 348 Engage Park Before Leaving VehicleCAS 349 Engage Park Before Switching Ignition OffCAS 413 Steering Column UnlockedConvertible Top ModuleCTM 267 Rear Window DriveCTM 268 Luggage Compartment PositionCTM 270 Convertible Top Not LockedCTM 271 Convertible Top, Vehicle SpeedCTM 272 Convertible Top FailureCTM 401 Roof Mechanism FailureCTM 416 Luggage Compartment PartitionCTM 432 Roof Drive OverloadCTM 445 Vehicle Not LevelCTM 516 Roof Operation CancelledCTM 518 Convertible Top Not LockedCTM 519 Roof Operation Not PossibleCTM 558 Roof Position DetectionCTM 559 Roof Drive OverheatedCTM 560 Roof Operation Not PossibleCTM 561 Roof Emergency OperationCTM 562 Roof UnlockedDual Clutch GearboxDKG 538 Gearbox MalfunctionDKG 539 Gearbox Malfunction 5-7DKG 540 Gearbox Malfunction PDKG 541 Gearbox Malfunction Manually Release Parking LockDigital Motor Electronics/Digital Diesel ElectronicsDME/DDE 25 Preheating, Please WaitDME/DDE 26 Cruise Control DefectiveDME/DDE 27 Engine Oil Level LowDME/DDE 28 Engine Oil Level Below MinimumDME/DDE 29 Engine Problem, Power ReducedDME/DDE 30 Engine Problem, Stop EngineDME/DDE 31 Engine Problem, Increased EmissionsDME/DDE 32 Fuel Cap OpenDME/DDE 33 Engine Problem, Reduce Engine LoadDME/DDE 39 Engine Overheat, Stop EngineDME/DDE 49 Particulate Filter MalfunctionDME/DDE 148 Brake Light Control FailedDME/DDE 182 Oil Level Sensor MalfunctionDME/DDE 212 Engine Oil Pressure, Stop EngineDME/DDE 213 Battery Not ChargedDME/DDE 220 Battery Discharge Rate HighDME/DDE 229 Battery Charge LowDME/DDE 247 Battery Monitoring FailedDME/DDE 257 Engine Temperature Too High, Drive ModeratelyDME/DDE 304 Check Battery ConditionDME/DDE 305 Check Battery TerminalsDME/DDE 306 Battery Charge LowDME/DDE 367 Engine Temperature Too HighDME/DDE 400 Engine Oil Level HighDME/DDE 427 Engine Oil Pressure LowDME/DDE 448 Fuel FilterDME/DDE 450 Automatic Start DeactivatedDME/DDE 492 AdBlue Reserve LowDME/DDE 493 AdBlue Reserve CriticalDME/DDE 493 AdBlue Reserve EmptyDME/DDE 506 AdBlue Fluid IncorrectDME/DDE 584 Transport Mode ActiveDynamic Stability ControlDSC 24 DBC Dynamic Brake Control Brake Assist FailedDSC 35 DSC FailedDSC 36 DSC/DTC DeactivatedDSC 42 DSC Control System/Ride Height adjustmentDSC 50 Runflat Indicator FailedDSC 63 Tyre FailureDSC 71 Brake Pads WornDSC 74 Brake Fluid LowDSC 184 Dynamic Traction Control ActiveDSC 215 Dynamic Stability ControlDSC 236 Brake and Stability Systems FailureDSC 237 Stability Systems FailureDSC 328 Brake Pad Wear SensorDSC 330 Hill Decent Control not AvailableDSC 331 Hill Decent Control ActiveDSC 332 Hill Decent Control DeactivatedDSC 333 Hill Decent Control not PossibleDSC 334 Run Flat System Requires StandardisationDSC 336 Dynamic Stability ControlDSC 352 Brakes Too HotDSC 353 Brakes OverheatedDSC 354 Start Assist InactiveDSC 364 RPA InitialisationDSC 382 DSC Restricted, Brake Pressure SensorDSC 384 DSC Puncture DetectedDSC 431 Brake Loading Too HighDSC 608 Tyre Pressure Loss, Front LeftDSC 609 Tyre Pressure Loss, Front RightDSC 608 Tyre Pressure Loss, Rear RightDSC 608 Tyre Pressure Loss, Rear LeftCorner Brake ControlDSC/CBC 42 Brake and Driving Control FailureTyre Pressure ControlDSC/RPA 50 Tyre Monitoring FailureDSC/RPA 63 Tyre PunctureX Drive ControlDXC 350 4X4 System FailureDXC 351 4X4 and DSC FailureDXC 369 4X4, DSC and ABS FailureDXC 370 4X4, DSC, ABS and EBV FailureDynamic Damper ControlEDC-K 43 Dynamic Damper Control FailedEDC-K 180 Dynamic Damper Control FaultElectronic Gearbox Control/Sequential Sports GearboxEGS/SSG 103 Gearbox Overheating- Drive with CareEGS/SSG 104 Gearbox Overheating- Reduced OutputEGS/SSG 105 Gearbox Overheated - Stop VehicleEGS/SMG 168 Transmission MalfunctionEGS/SMG 169 Transmission Position NEGS/SMG 170 Transmission Malfunction ResetEGS/SSG 171 Transmission Failsafe ActiveEGS/SSG 172 Transmission MalfunctionEGS/SMG 173 Transmission Position D OnlyEGS/SMG 174 Transmission Position P OnlyEGS/SMG 175 Transmission Malfunction, Position PEGS/SSG 178 Transmission in Neutral, Engage Parking BrakeEGS/SSG 179 Transmission MalfunctionEGS/SMG 203 Transmission Position in NEGS/SSG 248 Brake Signal Malfunction, Gears May Be Selected Without BrakeEGS/SSG 250 Brake Signal Malfunction, Gears May Be Selected Without BrakeEGS/SMG 251 Transmission Position PEGS/SMG 252 Transmission MalfunctionEGS/SSG 254 Transmission Malfunction Emergency ProgramEGS/SSG 255 Malfunction R,N,D Only With Engine RunningEGS/SSG 287 Clutch OverheatedEGS/SSG 288 Transmission Malfunction, Failsafe ActivatedEGS/SSG 289 Transmission Malfunction, Failsafe ActivatedEGS/SSG 290 Transmission Malfunction, Journey May Be Continued With CareEGS/SSG 291 Transmission Malfunction, Failsafe ActivatedEGS/SSG 292 Transmission Malfunction, Re-Select GearEGS/SSG 293 Press Brake and Select Neutral to StartEGS/SSG 302 Park Not EngagedEGS/SSG 307 Transmission Malfunction, Multiple FailuresEGS/SSG 322 Transmission Teach-in ActiveEGS/SSG 323 Clutch Teach-in ActiveEGS/SSG 325 Transmission in NeutralEGS/SSG 326 Transmission in DriveEGS/SMG 363 Transmission OverloadEGS/SMG 365 Transmission FailsafeEGS/SMG 366 Transmission Fault, FailsafeEGS/SSG 368 Transmission Failsafe ActiveEGS/SMG 394 Gear Selector LeverEGS/SMG 398 Engine Bay Cover OpenEGS/SMG 399 SMG State UndeterminedEGS/SSG 419 Drive MalfunctionEGS/SSG 420 Transmission MalfunctionEGS/SMG 446 Launch ControlEGS/SMG 557 Rolling Possible, Secure VehicleEGS/SMG 565 Gearbox Position P only Available when StationaryElectro Hydraulic BrakeEHB 439 Parking Brake OverloadEHB 452 Release AutoholdElectronic Height ControlEHC 45 Level Control System FailureEHC 245 Level Control System FailureElectric Fuel PumpEKP 216 Fuel Pump FaultEKP 309 Fuel Pump MalfunctionParking BrakeEMF 48 Parking BrakeEMF 51 Parking Brake OverheatedEMF 52 Parking Brake FailedEMF 53 Automatic Hold MalfunctionEMF 54 Parking Brake MalfunctionEMF 55 Parking Brake ReleaseEMF 56 Parking BrakeEMF 57 Parking BrakeEMF 58 Parking BrakeEMF 201 Automatic Hold DisabledEMF 210 Parking Brake FailedEMF 211 Parking Brake FailedEMF 239 Parking Brake FailedEMF 240 Parking Brake FailedEMF 241 Parking Brake FailedEMF 242 Parking Brake FailedEMF 243 Parking Brake FailedEMF 253 Parking Brake FailedEMF 395 Parking Brake MalfunctionEMF 402 Apply Foot BrakeEMF 410 Parking Brake MalfunctionEMF 465 Parking Brake FailureEMF 480 Parking Brake MalfunctionEMF 481 Parking Brake MalfunctionEMF 482 Parking Brake FailureElectronic Power SteeringEPS 73 EPS InoperativeEPS 385 Steering Assistance FailedHigh Beam AssistantFLA 374 Main Beam Assist DefectiveFLA 375 Main Beam Assist Not ActiveFLA 376 Main Beam Assist Not ActiveFLA 377 Main Beam Assist SensativityFootwell ModuleFRM 87 Right Rear Light FailureFRM 88 Dipped Beam Left FailureFRM 89 Dipped Beam Right FailureFRM 111 Number Plate Light Left FailureFRM 113 Sidelights Switched OnFRM 114 Rear Fog Light FailureFRM 115 Reverse Light Right FailureFRM 116 Indicator Rear Left FailureFRM 117 Reverse Light Left FailureFRM 118 Rear Light Right FailureFRM 119 Indicator Front Right FailureFRM 120 Dipped Beam Left FailureFRM 121 Dipped Beam Right FailureFRM 122 Indicator Front Right FailureFRM 123 Rear Light Right FailureFRM 124 Indicator Right FailureFRM 125 Indicator Rear Right FailureFRM 126 Fog Light Right FailureFRM 127 Side Indicator Left FailureFRM 128 Left High Beam FailureFRM 129 Rear Fog Light FailureFRM 130 Right High Beam FailureFRM 131 Parking Light Left Front FailureFRM 132 Front Right Side Light FailureFRM 133 Right Rear Light FailureFRM 134 Right Brake Light FailureFRM 135 Centre Brake Light FailureFRM 136 Left Brake Light FailureFRM 137 Number Plate Light Right FailureFRM 138 Fog Light Left FailureFRM 196 Indicator Front Right FailureFRM 197 Indicator Front Left FailureFRM 231 Light System FailureFRM 256 Headlight Leveling System FailureFRM 259 Window Anti-Trap DeactivatedFRM 261 Window Anti-Trap FailureFRM 345 Brake/Tail Light Failure RightFRM 346 Brake/Tail Light Failure LeftFRM 371 Number Plate Light FailureFRM 372 Brake Force Display Light Failure LeftFRM 373 Brake Force Display Light Failure RightFRM 378 Sidelight/Daytime Lights Defective- LeftFRM 379 Sidelight/Daytime Lights Defective- RightFRM 380 Turn Signal Lights Defective- LeftFRM 381 Turn Signal Lights Defective- RightFRM/ALC 295 Adaptive Cornering Lights FailureFRM 437 Parking Lights OnGear Selector SwitchGWS 393 Gear Selector PositionGWS 467 Gear Selector Malfunction/LockingLuggage CompartmentHKL 422 Luggage Compartment Lower LidHybridHYBRID 569 Drive Malfunction, StopHYBRID 570 Drive Range LowHYBRID 571 Drive, Only Forward Crawling Speed is PossibleHYBRID 572 Drive, Only Forward and Reverse Crawling Speed is PossibleHYBRID 573 Gearbox MalfunctionHYBRID 574 No Braking Energy ReclamationHYBRID 575 Refueling- WaitHYBRID 576 Refueling Only Possible When StandingHYBRID 577 Refueling PossibleHYBRID 578 Fuel Filler Flap OpenHYBRID 579 Fuel System MalfunctionHYBRID 585 High Voltage System MalfunctionHYBRID 586 High Voltage System MalfunctionHYBRID 587 High Voltage Battery LowHYBRID 588 High Voltage Battery, Switch Ignition on to ChargeHYBRID 589 High Voltage Battery ChargingHYBRID 590 Vehicle ReadyHYBRID 591 High Voltage Battery Charging AbortedHYBRID 606 High Voltage Battery Output RestrictedHYBRID 607 High Voltage Battery Regeneration RequiredIntergrated Chassis ManagementICM 474 Driving Performance Control FailedInstrument ClusterIKE 13 Radio Key in LockIKE 41 Service DueIKE 55 Parking Brake ActiveIKE 60 Speedometer FailureIKE 62 Vehicle Speed Limit ExceededIKE 78 Vehicle Speed Limit ExceededIKE 79 Low External TemperatureIKE 165 Low External TemperatureIKE 167 Reset ClockIKE 185 Gear Indicator FailedIKE 275 Low FuelIKE 279 Driver's Seat InsecureIKE 280 Passenger's Seat InsecureIKE 281 Service DueIKE 282 Instrument ClusterIKE 283 Instrument ClusterIKE 284 Service OverdueIKE 285 Service OKIKE 286 Fuel Low / RangeIKE 301 Seatback Monitoring FailedIKE 308 Parking Brake AppliedIKE 999 Instrument Cluster FaultJunction BoxJB 164 Windscreen Washer Fluid LowJB 166 Engine Coolant Level LowJB 183 Windscreen Wiper MalfunctionJB 207 Central Electronics Failure, Stop VehicleJB 415 Battery Discharge Rate HighJB 430 Transport Mode ActiveLongitudinal Dynamics ManagementLDM 1 Active Cruise Control Disabled, Poor ConditionsLDM 2 Active Cruise Control Disabled, Poor SignalLDM 3 Active Cruise Control FailureLDM 59 Active Cruise Control Disabled, Parking BrakeLDM 69 Active Cruise Control Disabled, Speed too LowLDM 85 Active Cruise Control Disabled, Hill DescentLDM 176 Active Cruise Control Disabled, Sensor ErrorLDM 177 Active Cruise Control MalfunctionLDM 199 Cruise Control FailedLDM 246 Active Cruise Control Disabled, Speed too LowLDM 276 Engine Speed Too HighLDM 277 Active Cruise Control Disabled, Gear SelectionLDM 278 Engine Speed Too LowLDM 337 Dynamic Cruise Control FailureLDM 338 Dynamic Cruise Control Deactivated, Parking BrakeLDM 339 Dynamic Cruise Control Deactivated, Excessive BrakingLDM 340 Dynamic Cruise Control Deactivated, Poor ConditionsLDM 341 Dynamic Cruise Control Deactivated, Gear SelectionLDM 342 Dynamic Cruise Control Deactivated, Speed Too LowLDM 453 Cruise Control Short Range Sensors DisabledLDM 454 Cruise Control Short Range Sensors SoiledLDM 469 Cruise Control Deactivated, Sensors SoiledLDM 478 Cruise Control Deactivated, Radio Astronomy InterventionElectric SunroofMDS 260 Sunroof Anti-Trap DeactivatedMDS 262 Sunroof Anti-Trap FailureMultiple Restraint SystemMRS 46 Fasten Seat BeltMRS 91 Fasten Seat BeltMRS 92 Front Passenger Seat Belt Pretensioner FaultMRS 93 Driver's Seat Belt Pretensioner FaultMRS 94 Rear Left Seat Belt Pretensioner FaultMRS 95 Rear Right Seat Belt Pretensioner FaultMRS 97 Multiple Restraint System FaultMRS 106 Rear Left Side Airbag FaultMRS 107 Rear Right Side Airbag FaultMRS 108 Driver's Airbag FaultMRS 109 Passenger Airbag FaultMRS 181 System Check FailedMRS 266 Rollover Protection MalfunctionMRS 389 Fasten Driver's Seat BeltMRS 390 Fasten Passenger's Seat BeltMRS 391 Multiple Restraint SystemMRS 392 Fasten Seat BeltMRS 612 MRS Acceleration SensorsNight Vision ControlNVC 356 Night Vision FailurePark Distance ControlPDC 195 Park Distance Control FailureReversing CameraRFK 424 Reversing Camera SoiledRFK 425 Reversing Camera FailureTyre Pressure ControlRDC 139 Front Left Tyre PressureRDC 140 Rear Right Tyre PressureRDC 141 Rear Left Tyre PressureRDC 142 Check Tyre PressuresRDC 143 Front Right Tyre PressureRDC 144 Tyre Pressure Monitoring FaultRDC 145 Tyre Pressure Monitoring DeactivatedRDC 147 Tyre Puncture DetectedRDC 149 Tyre Pressure Monitoring FailureRDC 192 Tyre Pressure Monitoring Deactivated, System InitialisingRDC 265 Check Tyre Pressures, MismatchRDC 327 Tyre Pressure Monitoring Deactivated, System InitialisingSensotronic Braking ActuationSBA 601 Braking System MalfunctionSBA 602 Braking System MalfunctionSBA 603 Braking System Sensor MalfunctionSBA 604 Braking System FailureSeat ModuleSIMO 436 Seat Position Detection FaultTelecommunications ModuleTCU 296 SOS Deactivated, Check PhoneTCU 297 BMW Assist DeactivatedTCU 298 BMW Assist Not PossibleTCU 299 SOS Call System FailureTCU 300 BMW Assist Deactivated, Check SIM.Time to Line CrossingTLC 435 Lane Departure Warning FaultVideo SwitchVSW 428 Side Camera Defective
