haywire;597732 said:my e39 530i still have its original battery that came with it when new. its year 2003 and is still strong, no electrical problem yet whatsoever.
astroboy;597729 said:It's recommended 5 years.. can't remember by who. Scary also ya.. dunno when it will die on you.. mine is 37 months liao.. and counting..
When it dies, door won't open. Pull the key out from the fob and use it to open trunk to replace battery. Make sure replace with battery N90 or above. Then need to register battery at OBC or not le? Anyone?
M3ac;597785 said:Apparently 5yrs is more likely for E46 (less electronics) and for E90 especially the LCI ones, it should be less due to the more electrical ancillariy requirements in the car such as comfort access, idrive, etc etc...
beemerx;597789 said:Mine's pre-LCI 320i SE without iDrive or comfort access...
astroboy;597797 said:Mine too.. no under door light, no footwell light, no DRL, kns! vanity mirror and light also don't have!! :14:
beemerx;598211 said:Ehhh... I think mine has some of the stuff you just mentioned Astroboy... so the under door handle lights, footwell light are categorized as comfort access is it? If that is the case, then yes :wink: I even have lights on both vanity mirrors
And DRL... there's an option to set it in the OBC. But mine is a 320i SE... should it come with all that?
astroboy;598214 said:Mine no front PDC, no electric rear blind, even the side mirror only do hand flips.. no motorised flips, no rear reading lights.. I think mine is 320i BLM, Base Line Model.. :4: Less electronic gremlins guaranteed! :top:
Confirm no DRL, only welcum light.. :lollypop:
beemerx;598223 said:Hmmm... I guess those stuff I just mentioned come in the SE (Special Edition) models... which I believe now it's standard on all the LCI models.
Which means my battery will have a much shorter lifespan compared to yours Astroboy.. not good.. not good
etquah;598226 said:Jerman use for 5 years right ?
M3ac;598253 said:If memory serves me correctly, the lights under the door handles are classified as Exterior Lights Package with vicinity lighting integrated in door handles and exit lights at front door. So I guess SE version comes with it. I believe you should also have rain sensor with automatic driving lights right? Xenon headlights for both low and high beam as well....
