Try
Bro, previously, I've seeing this kind of failure but my ride is e36 318
dono izit similar case with your ride. My indicator light up permanently
and I've tried to do some DIY. First thing, what u can do is, if you've
owned multimeter, try to do measurement on the battery to ensure
that the voltage of the battery is range 11.5v to 12v, if below than
that, considered the battery no longer can be used. So, I've decided
to change for new battery, after that no more problem encountered.
May be other Sifus can give more advices.
p/s: Pls do not delay to replace the battery, its might will affected ur
other electronic stuffs.
