Balancing Prop. Shaft
CAJ19
Tabiks to all sifus..... Could anyone of you sifus tell me where can I get my E34 prop. shaft balanced? As usual, E34 disease, shakes like crazy upon reaching the treshold of 80km/h. Bearing already replaced. It'll behave well for a while, then shakes again. Maybe its bent or imbalance. Need to get this piece of shit balanced........Please tell me where????/
When changing center bearing, make sure da bolts holding them 2
da body is properly aligned.Coz da bolts r placed in a slot,not holes.
Even a few mm could cause vibration...mine did.
M not sure wat E34 model u r driving but if urs has coupling bush between
da long shaft n da gearbox,its worth looking into it since urs vibrates
at 80kmh...I pressume vibration is fr under da body below gearbox.
How's ur gearbox mounting n da rear differential bush?
If all these do not help, ur long shaft might need 2 b serviced...
Not sure which engineering shop 2 recommend coz hvn't found any good ones yet myself.
Regards B)
