Anyone with B8+eibach and on 18" wheel?
bmwjackiee36
Just want to check who is on B8+eibach with 18" wheel? Most of the guys with 19" wheel do not have rubbing issue but on normal 18", there is rubbing.... Any guys out there have this issue? If possible, could share tyre size if using 18"
If u use the correct offset rims, there is no rubbing issue in whatever lower (not extreme lower ya). Should check the rims offset if u have the rubbing issue.
But the problem is that it is using std rim....
18" tyre is 245/40/18....
Could it be installation issue? or part issue?
tyre size is correct...
still have to ask what offset is the rim...
we are just worried if the rim is standard for say, an E90 and not for E60...
Is it for E60? I was on the set previously on 18" and now on 19". No rubbing issue. Only issue i got is my back always itchy and need rubbing
sachseelan;658817 said:
kasi negative camber lagi, cantik
:tongue:
Cannot la bro BMW ori camber setting redy -ve. cant go more or tyre makan dalam.
Then I lagi jialat makan hati. Good suspension and tyre is more than enuff for me.
What is the air pressure that we should set when we pump air onto a 18" 245/40/18 tire?
Try checking the manual, it's normally stated there. If you don't have it, try downloading. I got mine from the manual too :)
Interested in this setup.
But many people say it's too Hard/Firm for Malaysian roads.
What are your views?
