are u using the full set or just the springs?how much did u pay for it?BMW7 said:nice car.......I use Eibach for my E-38......very comfort. No problem
ez77 said:M30, i already lowered my E23 recently. I only go to workshop cut-off 1.5 ring from the original coil. My ride is more smoother and the connering more better than b4. Just RM40 for the workmanship, no hassle done.
whl said:I would say its not generally recomended to "potong coil" but if its looks your looking for then go ahead. Anyway RM1300 for a set of Eibachs is pretty reasonable because original is aboout RM 200 plus a piece, but I doubt if you can find Eibachs for e23 brand new.
Alternatively use e32 springs for the rear, I use it on my car and the rear doesn't sag as much under heavy loads. I don't think front can fit e32 springs though.
Mazin aka whl
M30 said:After market springs that i found is RM680 for all sides. Lower the car by 30mm, but not sure if that is low enough or not. I am still trying to get the original ride height or ground clearance so that i can look for the springs that lower my car to the height i wan.
Do u think i can fit the e32 sports springs on all sides?
whl said:I don't e32 spring can fit in the front. So what after market spring have you found?
Mazin aka whl
