Z Zaba_Zul New Member Joined Apr 17, 2017 Messages 5 Points 0 Apr 17, 2017 #1 What is the cause? Correction : aircon water leak onto car mat right hand side rear and driver Sent from my iPhone using Tapatalk
M moots Club Guest Joined Dec 10, 2004 Messages 1,600 Points 83 Apr 18, 2017 #2 The a/c drain hose dislodging from it's correct routing will cause this. Question is how did it get dislodged unless work was done at that area.
Z Zaba_Zul New Member Joined Apr 17, 2017 Messages 5 Points 0 Apr 29, 2017 #3 moots said: The a/c drain hose dislodging from it's correct routing will cause this. Question is how did it get dislodged unless work was done at that area. Click to expand... Sent from my iPhone using Tapatalk
Z Zaba_Zul New Member Joined Apr 17, 2017 Messages 5 Points 0 Apr 29, 2017 #4 Zaba_Zul said: Sent from my iPhone using Tapatalk Click to expand... I also wander Sent from my iPhone using Tapatalk
Z Zaba_Zul New Member Joined Apr 17, 2017 Messages 5 Points 0 Sep 13, 2017 #5 Found the root cause- water thru bunch of wiring hole under the dashboard (driver's side), there is a container which was clogged in engine compartment (driver!s side) Sent from my iPhone using Tapatalk
