advise needed sifu's: when brakes no signal, no radio, no wiper....
vinesmaran
the problem with my car that when i brake all goes off;1. Radio2. Signal3. Brake light + third brake light oso4. Wiperno function at all then after a while it will then comes back when braking.....is it wiring short circuit......this intermittent also...........its dangerous also...when this happen i need to use my hazard lights to acknowledge that i'm braking............does anyone this issue before???pl advise what can be done.. :102:
Could be bad connection between the switch/wiring and the fuse block. Get a good wire-man to check bro !
Bro check your battery and alternator.
I kena once. When braking, radio went dead, RPM gauge dead. Turned out to be alternator dead.
