Hi Bro hafiz, for me e36 318 is not too hard to maintain and i'm using it for the daily
drive. For the normal service, its just like others jap cars and its not too expensive
due to its only have 4 cycl, 4 spark plugs and used only 1 bottle oil. Everytime i do
the car service only spent out not more than rm300. For 318, its a bit under power
but if your're not a person who's like to drive fast, i think 318 just enough for daily
drive. If you think of the performance and like to drive fast, so go for 325 or 328.
Pls bare in mind, BMW car is a pampered car, you must follow the schedule on time
to replace any broken parts without any delay. If not, you'll facing huge trouble in
future. So, if you tend to buy the 2nd hand car, pls allocate some money around
rm5k to 10k for wear and tear parts for replacement, coz we don't know how well
the previous owner taken care of the car. Do not rushing, you got to spend some
time and be cool for searching the car. Below are some tips for you to check on the
second hand car, might be other sifus can add-on more.
Tips:
1) Pls check any leaking for the radiator(water level) ***the most important***
2) Check all the hose (for radiator connections) whether its still in good condition
3) Try to observe any water leaking at the water pump area.
4) Check any oil leaking (top and bottom engine)
5) Check the oil deep stick, try to observe is there any particles mixed up with the engine oil
6) Try to start the engine and wait about 10 to 15mins then ensure that the radiator fan
is trigger to turn on whenever the temp gauge touch at the middle level.
7) Test drive and try to shift the gear to ensure that no hard jerking during the gear
shifting. Gearbox quite expensive lor... heheheh...
8) Check the aircond, working or not
9) Try to check the car's frame, to ensure that its not the potong kereta.
10) First thing to do, pls change the oil engine and gear box oil after you got the car.
After you got your dream car, then we can start to racun you... huhuh...
Anyway, good luck on your hunting BMW...
