Adjustable Suspension enquiry
BMW520
Dear all sifu,I plan to lower my e39 after install bodykits & repainting. I come across few type of suspension & not sure its performance & confort level & if the price is reasonable...all price stated including installation1. HWL (high low only) RM38002. BC (high low hard soft) RM34003. GAP (high low hard soft) RM3200Besides, another option is change eibach spring 4pcs(RM1350) include installation or 2pcs pack from ebay (RM600) without installation.Appreciate to get some feedback if you use these adjustable suspension b4....Another question is, will it be any problem is just change 2pcs front spring?
I am using Bilstein PSS, one word: SOLID!
I heard a lot good comment for BC. U might consider Titan too.
i m on Titan .. not bad for the price. Handling is solid but not rock solid. I have changed my settings 5 times - telling Richard to make it harder, everytime.
After the 5th time, i gave up. Braking while taking corners is scary ..
KW2 for me - if i have the money ..
Same experience on my E36 for Titans. KW's and PSSX have good reviews. On a cheaper option, BC Racing and K-Sport has good reviews as well.
do not go for the al-chepo ones ...surely regret one .... get those repurtable ones ....yehh it do cost a little more ...but it's worth the pleasure ...
Thanks to all Bro...seem like Titan & BC is more ppl consider...Btw, Titan & Blistein cost how much? Is the shox serviceable? Is Blistein n Titan come with spring?
Bilstein is the most expensive amont what u quoted above. It comes with spring.
BMW520;691180 said:
I've had 2 sets (that's 8pieces!!) of GAB for my Suckria (read: Satria) and they both leaked & fell apart. Avoid at all costs.
Thanks bro....will look for blistein, titan, BC or just eibach spring...either new or used will do...i'm looking for used eibach spring for year, still very hard to get...not sure if have luck on the suspension..
WOW so unreliable!!! Even the seller also recommend not to use GAP...i think that's the reason...its local made...thanks Chrix for sharing..
Used Eiback should not really hard to get i think.
Why not H&R? That's a bit tough to get.
Between, i have a set of TERRA lowering spring for e39 in my store, u interested?
You can reuse your stock springs for Titan. I paid 2.4k for 4 pieces with 2 yrs warranty.
It is serviceable @ RM 100 per shock.
Last checked at Redzone sunway yesterday.
Bilstein B8 - RM 3300 + Rm 200 installation
Bilstein B12 - RM 3800 + Rm 200 installation
Seems like u slow slowly start to mod your car ehh..
Can i know how many mm lower if install with Titan + stock spring?
Not hard to get new eibach but not for used...used spring for suspension not really easy to get with reasonable price...
U can set ur ride height . Just inform him your preference.
