ok here are your options....i am in a talkative mood today.
1. M20b25 stock standard, play on the exhuast and intake, springs, absorbers, rear disc, ARB.
2. M42b18 stock standard, same thing as the above
- If you want to do more things...like cams, port n polish, stroker kit ....basically the engine internals..it will cost you about 15K parts only. not including the labour.
3. m50b25 stock standard (e34 manual halfcut), custom springs, custom absorbers, ARB to match new suspension, rear disc, matching rear axle, exhaust system and intake system
4. m20b27 eta conversion.....commonly know as a simple procedure...Not really...here is what you need to do.
- you need 2 engines....m20b25 and m20 eta engine...why....the head of the 2.5 with porting and polish would be the optimum for the conversion. The motronic system would be the best option for this conversion.....running on the ljet would not be limiting and underfueling the engine.
- yes you can skim the 2.5 pistons or the eta piston but it will probably give you a crappy compression ratio of 8:1 which is a lot less than a m20b20. The best solution would be to get yourself a set of custom pistons....JE, Metric mechanic, Ireland engineering, Korman bmw with a compression ratio of about 10.5:1 and that would cost you about RM4000 without shipping.
- when doing this whole conversion you are basically opening up the entire engine....so a complete overhaul is wise to do and replacement of all worn out parts.
-there is no way you are going to get a CR of 11:1 or 10:1 by using the standard head 2.0, 2.3 , 2.5
- the m20b27 standard ETA engine was designed for low end torque at low revs, yes it has torque, it basically behaves like a bus or a lorry. If you use the ljet 2.0 ecu it will be better than the eta ecu but you are still underfueling your engine. the mapping of the 2.0 and 2.3 ljet ecu is not sufficient to cope with 2.7 displacement. you are slowly killing your engine.
- now since you are opening up the engine...you might as well drop in some cams.....easier said than done...depending on the cam degree you would need titanium vavle retainers and stiffer vavle springs....you standard ones wont hold in the long run. again more money spent.
Which leads me back to my first question whenever someone asks about how to get more power......
......How much are you willing to spend and do you know what you want????
